I've made a different thread before on how applications would take multiple attempts to start up because of an error. It bothered me, but I dealt with it. Now, my Discord broke; something about it has been destroyed as shown in the attached picture. I'm fed up. Might as well ask Geek Squad for help at this point. I'm going to be required to reinstall a program and I don't even know what's going on. I checked the health of both my SSD and HDD, but they showed up in "Good" condition. Help?
Crimson Panda
http://pcpartpicker.com/list/g6T8QV
AKG K712 PRO
OL DAC
Magni 3
https://linustechtips.com/topic/884069-pc-process-going-haywire/
This is probably some funky windows corruption that nobody can fix. (not even the lords of tech, geek squad).
However, a reinstall of windows will almost certainly fix the issue.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Gee, that's a real drag. Can you list some steps on how to, as I've avoided doing this for so long?
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
Like RadiatingLight said, it's probably just random, and a re-install of windows will probably fix it.
However, you should also run a full memory test by downloading and using Memtest86 from a bootable USB flash drive.  There is a slim chance your RAM could be the culprit causing the corruption to begin with, especially if your storage devices already tested OK.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
So... install memtest86 onto a usb flash drive. Turn off my PC. Plug the flash drive in. Open my BIOS. Change boot to usb. Restart?
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
Pretty much.  Or when you boot, there's usually a hotkey for "Boot Device Selection" so you can bypass going into BIOS to change it.  It's different for each manufacturer, but usually is Escape, F9, F10, F11, or F12.  It may or may not say it somewhere on the screen during POST.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
Time to spam restart to find out haha.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
If memtest86 doesn't find any errors (i don't think it will) then you can reinstall following these steps:
BEFORE DOING THIS, BACK EVERYTHING UP. YOU WILL LOSE ALL DATA ON YOUR OS DRIVE
1. get a blank USB stick 8GB in size or more (it will be formatted, so make sure it's empty or the files are unneeded)
2. download the boot media creator from this site https://www.microsoft.com/en-us/software-download/windows10
3. select "create media for another device", then select your USB flash drive
4. boot from it in the BIOS
5. follow the instructions to install windows
6. when prompted for a product key, click the button that says "i don't have one"
Laptop:
Will I lose files on my HDD?(not os drive which is the ssd)
You only mentioned Os drive, so......... I'll ask this dumb question.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
When you boot from the USB, it gives you a choice of where to install windows. if you can identify your drives based on capacity, then you can correctly choose the SSD to format and install on. if your SSD and HDD are similar in capacity, then just to be safe, unplug the HDD when installing.
Laptop:
I see, my files are safe then.
Crimson Panda
AKG K712 PRO
OL DAC
Magni 3
