My pc was running fine just a few hours ago. I opened it up to change my power supply and graphics card and when trying to boot back up my motherboard didnt post and had the 00 code. I decided to remove everything from my case and test the cpu and mo-bo individually. To my surprise i discovered that my cpu was burning hot even though i have a water cooler and the mobo was also burning hot around the cpu area. As you can see from the attached pic all the mobo leds light up.  I dont know if either of my parts are broken, can anyone help me out?
https://linustechtips.com/topic/883933-i-need-help-urgent/
Why would you boot it up with no cooler attached?
Also, that CX psu is total crap, get rid of it.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918666
There's no cooler on your cpu.
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918668
Describing it as 'burning hot' could mean you've cooked the CPU and the power delivery on the board
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918669
Of course it is going to get hot... Put the cooler back on, with new thermal compound if possible. Re-seat the CPU, check the motherboard for any bent/damaged pins. Be sure to tighten the cooler down properly, in an x pattern. Put the old gpu in the system since it is known good, and re-seat the RAM. Then try booting again.
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918697
remove the mobo battery and the ram, replace thermal paste and put everything back inside the case, then try again
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918703
Just now, Kered124 said:
Of course it is going to get hot... Put the cooler back on, with new thermal compound if possible. re-seat the CPU, check the motherboard for any bent/damaged pins. Be sure to tighten the cooler down properly, in an x pattern. Put the old gpu in the system since it is known good, and re-seat the RAM. Then try booting again.
I have done all of this. Please don't state the obvious. I just need help determining what broke and how it broke. I didn't fry the cpu, my system was fully built with my water cooler on and it still didn't boot, the keyboard and mouse didn't light up. The picture is me showing the mobo leds
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918707
8 minutes ago, Tim666ish said:
I have tested my old mobo and cpu with no cooler and it boots just fine
Hahaha, old stuff was soldered, Intel nowadays uses toothpaste instead, you killed your CPU if you forced boot without a cooler
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918710
What specific CPU is it? and what exact motherboard model?
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918718
5 minutes ago, Kered124 said:
Is it just me, or in the picture does it look like the RAM isn't pressed all the way in at the top? The very first locking arm appears to be in more than the one on the RAM module...
Nah it was pressed in all the way, it just looks weird
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918762
Yes, but i actually tried booting with my watercooler inside the case before removing everything and testing like this
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918766
2 minutes ago, Tim666ish said:
And so I shall
When you boot, LED's that are below the postcode turn on in sequence and then go out, if they stay on, it indicates a problem with that specific component. Page 29 of your manual: http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/MAXIMUS_IX_HERO/E12186_MAXIMUS_IX_HERO_UM_V2_WEB.pdf?_ga=2.236982080.1566293700.1515287374-1273242037.1514251472. Q-LED.
Intel Core i7 8700k | be quiet! Dark Rock 4 | Fatal1ty Z370 Gaming-ITX/ac | 32 GB G.Skill TridentZ | 256 GB Intel® SSD 600p Series | ZOTAC GeForce® GTX 1080 Ti Mini | Fractal Design Node 304 | Cooler Master V750 | Asus MG279Q | Asus VC279 | Logitech G710+ | Corsair M65 Pro RGB
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918822
None of the lights turn on, the system appears to turn on but nothing happens, only the 00 code and all the fans start spinning but no keyboard or mouse lights and it certainly doesn't post
https://linustechtips.com/topic/883933-i-need-help-urgent/#findComment-10918981
