Hello, i start noticing that my only fan, its a rear exhaust fan ,is ramping up a lot, if i turn it down the system get too hot and the cpu and gpu fans start to ramp up.
So my question is should i change the fans position and make it a front intake fan until i get a a second for exhaust or wait until i buy one and put as a front intake. Just to clarify my problem is it get loud, my temps seem fine
The front supports up to 2 120 mm fans and the rear is also 120 mm, not top mounted tray, my case is a cheap bitfenix.
CPU: AMD A10 5800K @4.2 Ghz about 50-60 C under 100% load
GPU MSI R7 250 2GB @1130 Mhz core and @980 mhz mem about 55-60 C under 100% load
https://linustechtips.com/topic/883772-fan-placement/
You should get Front intakes that are filtered. Atm you have under pressure in your case which will result in more dust because it will suck in air at any small gap where no filters are at.  I would go for 2 120 millimeter front intake and 120 mm back exhaust to have over pressure / balanced air pressure.  Hope you already got dust filter at front.
https://linustechtips.com/topic/883772-fan-placement/#findComment-10916855
yeah i know, in my opinion the positive air pressure work better, the front is filtered, i m just asking if i move the fan to the front is it gonna help with the noise?
its gonna be some weeks before i buy fans tho
https://linustechtips.com/topic/883772-fan-placement/#findComment-10916873
I would look in to buying better made fans for the case 3 120mm.The lower bd the fan the quieter is it and the higher cfm the more air it can move.And if you have that fan pluged in the motherboard its probably running pwm and reving up when the pc gets warm.
https://linustechtips.com/topic/883772-fan-placement/#findComment-10916877
Moving that fan really won't do much for quiet,You really need 2 more fans if you want it quieter.3 fans can more more air then one,And if they are pwm they will only rev up when needed.
https://linustechtips.com/topic/883772-fan-placement/#findComment-10916879
good, my mobo doesnt support pwm but i think that a pwm fan header would fit a regular mobo fan header, what fans do you recommend, high airflow or silent?
https://linustechtips.com/topic/883772-fan-placement/#findComment-10916890
2 hours ago, CUDA_Cores said:
If you want your system to be quieter, you need to add more high qality fans to your system. Then take those fans and slow them down to their minimum speed. Four fans moving at 500RPM are going to move the same air as a single fan moving at 2000RPM but the four fans are going to do it with a lot less noise.
This technically isnt true. Each fan has a CFM (cubic foot per minute) value assigned to it at each RPM level, and IIRC the ratio isnt 1:1 in terms of air moved relative to the RPM. Also have to take into account the size of the fan. A 140mm fan at 2000 rpm could move more air than 4 120mm fans @500rpm (I know you know all this, I just want to clarify the statement)
That depends on what you care about. Do you care more about silence, or air flow? Noctua makes great fans that excel in both (they aernt the best in either, but theyre up there as the perfect balance) but theyre very expensive.
https://linustechtips.com/topic/883772-fan-placement/#findComment-10917183
right now my system is pretty cool due to low tdp components, i do plan to have an upgrade in the future tho, but i mostly like it to be silent and decently cool, im ok with over 60C on cpu and gpu on 70-90% load. so some nuctua's silent fan or the new coolermaster silencio?
https://linustechtips.com/topic/883772-fan-placement/#findComment-10917572
Depends if you for example have a CPU cooler with fan near exhaust it should work fine. What also matters is PSU placement can you post pics of your case with open side window.
https://linustechtips.com/topic/883772-fan-placement/#findComment-10917760
