I have a max budget of 50 USD that I might want to spend on an air cooler for my PC upgrade and was wondering which one I should get. I've seen a lot of names tossed around lately such as the Noctua NH-D15(the color though) and the Cryorig C7, and I started wondering how much better of an air cooler I could get for $50 than the included Wraith Stealth that comes with the CPU I'm getting.
https://linustechtips.com/topic/883650-which-air-cooler/
1 minute ago, ScrappyZeDog said:
I don't know about the difference, but I have heard the Hyper 212 Evo is a good cooler.
I have been thinking about that one as well, although I've heard from a friend who has it that it's a pain to mount
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10915562
The Hyper 212 EVO is a very reputable cooler but it's really not worth the extra price. The 212 EVO often will provide the same cooling efficiency as the Wraith when idle, is slightly louder, and requires an aftermarket AM4 mount. I'd watch this video if you'd like to learn more.
Instead, I'd suggest that you stick with the Wraith and save up to invest in a Noctua NH-D15 or Be Quiet! Dark Rock 3.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10915618
1 minute ago, WhatsTheWifiPassword said:
which cpu amd or intel??
AMD. Specifically Ryzen 5 1600(I mentioned that it came with a Wraith Stealth cooler in my OP right?)
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10915619
-snip-
I don't have any fans to replace the Noctua ones with so that's out. What about the Pure Rock/Pure Rock Slim?
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10915629
The BK013 Shadow Rock 2 is slightly more efficient than the 212 EVO. I would not go with the Pure Rock series.
Desktop
Homelab
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10915650
What case and ram are you using?
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10916168
Specs are in my signature, but I'm using an NZXT S340 and a single stick of G.Skill NT series memory(generic DDR4)
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10917664
160mm limit only then. C7 and D15 are two ends of scale. One being low-profile non-OC cooler and other being king of them all. I would say you can pick any of the budget coolers; 212 Evo, H7, Gammaxx400, Pure Rock and be happy about it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10917956
Depending on how much you'd prefer to spend,
Kotetsu: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
Mugen 5 Rev B: https://pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-512-cfm-cpu-cooler-scmg-5100
https://linustechtips.com/topic/883650-which-air-cooler/#findComment-10918612
