2 minutes ago, Bennettboy9 said:
U can see by the pic..... yeah
carefully grab the edges without touching the pins and twist the cpu side to side
the sticking between the heatspreader and your cpu will have stopped and you can safely place your cpu back in the socket where it came from
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10914357
just twist it off.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10914359
So the cpu is stuck to the heatsink.  Try using some denatured alcohol, beer won't do it, alcohol content not high enough.  Put some alcohol in a small bowl or tupperware dish and set the cpu in it and let it soak.  The alcohol will eventually loosen the thermal paste and you will be able to remove it.  Don't forget to use thermal paste when putting the system back together.
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10914365
oh ffs, JUST TAKE IT OFF. It's not going to self destruct...
System specs:
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10914372
1 minute ago, kb5zue said:
I would much rather it come apart without having to force it.  The more you try and force things, the higher the chance of something going wrong.
have you ever seen the movie Idiocracy?
I feel as if I am the 500 year old soldier...
IT'S NOT GOING TO BREAK.
System specs:
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10914391
Use Gatorade as a solvent.... it has electrolytes... it's what the CPU needs.
But honestly, twisting will get it off. A bit of isopropyl alcohol will loosen it if necessary.
I haven't lost my mind, it's backed up on tape somewhere.
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10916176
you got a hair dryer? try warming up the area around the CPU, it's generally suggested to run the PC for a little while before shutting down and IMMEDIATELY removing the heatsink and when removing the heatsink twist it BEFORE lifting, but none of that will help you right now aside from warming it up.
https://linustechtips.com/topic/883532-cpu-stuck-pls-help/#findComment-10924320
