I am planning on upgrading my pc of 4 years with the release of intel 8700k 6 cores cpu and the rising popularity of tempered glass cases. My case of choice is the Corsair Crystal series 460x non rgb version since i already got plenty of nzxt rgb case fan with the HUE+ controller. I am planning on using Cooler Master MasterLiquid ML240L AIO in a push=pull config in the front but with my existing Asus GTX 1070 being kinda long, can someone let me know if it is possible with these parts?
I've also consider doing a top mounted radiator with push-pull but thinks it wont looks right as it will be showing alot of the radiator from the side panel and also might not give enough height clearance with corsair vengeance rgb RAM.
https://linustechtips.com/topic/882770-built-parts-compatibility/
Go for the Thermaltake Ringg RGB AIO instead. I wouldn't build in the 460X, heard it's tiny and terrible to work in.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
i was thinking about the thermaltake AIO tooo but the coolermaster AIO would sync with my asus mobo's aura sync and thermaltake will not. And yes i've heard about the size problem too, but i cant find any other case the have both a front and side tempered glass and the 570x is too big and i dont like the right side panel showing my cables.
