First post begging for help?
CHECK
1. Budget & Location
$4k & USA
2. Aim
- Video editing for both Drone video capture as well as gaming video editing.
- Streaming both to an internal capture card (do not include in build as I already have plans for an el gato HD 60 pro) and streaming games whilst playing them on PC.
- TONS of hours of gaming will be done on the PC so it's VERY much a gaming PC more even than video editing.
- QUIET as can be. I have my gaming desk in my bedroom where me and my gf sleep. I stay up much later than she does and I need to be able to ensure that the PC isn't running mega loud for obvious reasons. (Plz no doghouse/couch)
so I'd love CPU and GPU liquid cooling and quiet fans.
- Fast M.2 drive Paired with 3TB+ 7200 RPM HDD.
- Future Proofed as much as possible. I would like to be able to upgrade it if needed in the future or have something that is powerful enough that upgrading isn't going to be a thought in my head for years to come.
3. Monitors
I need new monitors, actually. 1 can be on monitor riser but 1 needs to be able to be wall mounted to fit the space I currently have available.Wouldn't be opposed to mounting both monitors on wall though if it's easy enough. Flat wall behind the monitors. Unfortunately screens can't be HUGE as the space is pretty small. Currently using 2 23 inch monitors. I can add some to the budget for these but if possible to keep in $4k price total that would be awesome.
4. Peripherals
- Need windows
- Need monitors as listed above
5. Why are you upgrading?
Got a GREAT offer on my old desktop + laptop. Practically no money being lost from purchase price and together give me enough to get a nice PC along with birthday/christmas money from relatives. I love computers but I just don't know too much about higher end parts anymore.
Anything questions AT ALL that would make your life easier, other than my Runescape user and password, I will HAPPILY answer.
Thanks,
NibbStra
https://linustechtips.com/topic/882578-higher-end-build-help/
7900pocketheater + Rampage VI EXTREEEMEE
GTX 1080Ti*2
2*360mm waterloop with NF-F12s and quiet pumps
Btw which drone do u have? I use Mavic Pro
3 minutes ago, NibbStra said:
NibbStra
thats not how you write it, this is the right way: Ni?️?️Str?️
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/882578-higher-end-build-help/#findComment-10905994
I guess in response to both of you, which I should have included in the beginning.
My uncle does Aerial photography and videography and it has really got me interested. I haven't YET purchased my drone (income taxes boiii) but I plan on getting the DJI phantom 4, to follow in his footsteps (His Insta: https://www.instagram.com/flyingdreamsais/?hl=en). I also do not YET have video editing software (so this is all gonna be new to me). Fortunately I have a TON of people around me that are graphic designers, video editors, and photographers. First step for me is a PC that can handle it. So if there is a solution for video editing you can include what software would work best with the hardware you suggest.
Sorry for the unfortunately unhelpful response :(
https://linustechtips.com/topic/882578-higher-end-build-help/#findComment-10906081
Something like this should be decent for the CPU and GPU. If the load really GPU heavy, and benefits from raw GPU power, SLI 1070 Ti or 1080s might be better.
You can change the storage configuration as you please.
CPU: Intel - Core i9-7920X 2.9GHz 12-Core Processor  ($1099.99 @ Amazon)
Motherboard: ASRock - Fatal1ty X299 Gaming K6 ATX LGA2066 Motherboard  ($236.30 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($184.99 @ Newegg)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.89 @ OutletPC)
Storage: Crucial - MX300 1.1TB 2.5" Solid State Drive  ($269.00 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  ($769.99 @ Newegg)
Case: Fractal Design - Define R6 Black TG ATX Mid Tower Case  ($164.98 @ Newegg)
Power Supply: Corsair - 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($189.89 @ B&H)
Total: $3228.02
Generated by PCPartPicker 2018-01-06 15:32 EST-0500
And the loop
https://www.ekwb.com/custom-loop-configurator/shared/oW5a5132019017f
https://linustechtips.com/topic/882578-higher-end-build-help/#findComment-10906118
Total: $3228.02
And the loop
Thanks for the suggestion! I like it a lot, however is the cooling usually that expensive or is that a really good brand? Not heard of it myself.
https://linustechtips.com/topic/882578-higher-end-build-help/#findComment-10906697
Custom loops get really expensive really fast. They do make some cheaper kits, however with an HEDT CPU, you'll want some VRM cooling.
You can have a look around their site, or around this site.
http://www.performance-pcs.com
https://linustechtips.com/topic/882578-higher-end-build-help/#findComment-10906741
