I could be wrong but I think G.Skill makes specific sets of that RAM for AMD CPUs.
CPU: Intel Core i5-4460 3.2 Ghz Quad-core  Motherboard: Dell 088DT1  RAM: Generic Dell 2x4 GB DDR3  GPU: EVGA Nvidia GeForce GTX 1050 Superclocked  Case: Corsair Carbide Series 400C - White (with Cooler Master LED Strips)  Storage:  Seagate Barracuda 1 TB  PSU: EVGA 500 W1, 80+ WHITE 500W  Monitor: Asus VS247H-P - 23.6 Inch  Cooling: 3x Corsair AF120 and 3x Corsair SP120 Case Fans  Keyboard: Corsair K95 Platinum RGB  Mouse: Logitech G502 Proteus Spectrum (Corsair MM300 Gaming Mouse Pad)  Headset: Logitech G930 7.1 Surround Sound Headset  OS: Windows 10
https://linustechtips.com/topic/882267-ryzen-build-question/#findComment-10903120
Here is a list of compatible AMD memory. It may or may not work, but just to be sure, find the model number in here
https://www.amd.com/system/files/2017-06/am4-motherboard-memory-support-list-en_0.pdf
https://linustechtips.com/topic/882267-ryzen-build-question/#findComment-10903127
Doesn't look like like my model is on the list. F4-2400C15D-16GTZR
https://linustechtips.com/topic/882267-ryzen-build-question/#findComment-10903146
