Hi! A friend of mine is a professional photographer, and is getting the new iMac Pro. At the same time he wants to get a NAS and work off that, which means everything will be stored on the NAS.
Although i recommended running it in Raid 1, he specifically wanted 1x3.5TB Seagate Wolf Pro for "active use", and automatically backing up that "active use" drive individually on 2 other 3.5 TB drives. Which means he's going to have 2 backups. Is this doable with any of the raid configurations, if not is there a script to run that automatically backs up all the content on the drive at specific times?
Please ask if I need to clarify something.
https://linustechtips.com/topic/880676-nas-storage-method-question/
It's possible to use multiple RAID configs in FreeNAS, or just have multiple RAID0/5/6/10 boxes.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
Well RAID is not an alteranative to making backups, just redundancy in case of drive failure (aside from RAID 0). So if having backups is the main priority, get a script or something similar that backups the required data once in a while.
Perhaps use two drives for a RAID 1 and the third one as backup?
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
RAID is NOT a backup. If the system he is running it all on fails, or if there is a power surge etc, all the data will be lost. You could easily make that strategy work with scripts to copy files across, or using multiple drive mirroring, but I would suggest another solution.
RAID 1: Two of the 3.5TB drives.
Cold Storage Backup: Another of the 3.5TB drives, that you can update periodically, potentially via a hot swap drive tray in the front of the case.
It is also worth considering a cloud backup as well, especially if this data is very important.
This can be achieved by using Freenas (I would recommend ZFS), or pretty much any other NAS solution.
Raid 1 doesn't care how many drives are attatched, it copies the data to all attached drives.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
As i don't think there's a "right way" to do this, i won't mark a solution. But i'll be taking all your input and looking into how to set up the different options you guys gave me, and then with my friend come to a solution as to how he wants to do it! Thanks a lot for all the input guys! :)
Indeed, many routes lead to Rome :) I think the main point made here is that you should not go for RAID when a backup is really what you want.
