I can get 5Ghz on my 8700k but only at 1.350 V, at which in aida 64 temps sore to 90 degrees or more on all 6 cores. I know it won't get that high in gaming but should I just run it at my current settings of 4.7Ghz at 1.264 V
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/
I'd keep it at 5GHz and just get a better cooler.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880276
This is with a h115i.
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880277
Maybe just keep it at a lower clockspeed.
SPECS:
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880279
Max fan speeds, max pump speed, swap the turbo jet crap on your cooler for something good and you can also delid if you want to really bring down temps
Builds:
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880380
I'm not running max speed on the fans due to the noise. Running the pump at 100% for the amount of time I play would kill it ALOT faster. I haven't used the stock thermal paste. Not deliding as I like warranty
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880430
Then swap the fans for something that isn't crap, like Noctuas new Chromax series
Builds:
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880500
Only way to get better temps than that (without resorting to custom loops) is to delid your CPU (and apply liquid metal).  Unfortunately, Intel doesn't solder the CPU die to the IHS and uses crappy thermal paste so this is what you get.
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880518
1. Delid
2. run at current speed
3. run at 4.7 (coulda just gotten an 8700)
pretty much in that order by preference. I know u said u like warranty but the cpu is the last part i expect to break within 3 years, pretty much stopped caring about warranty on the cpu.  By not delidding you are running it hotter and it'll be weaker when the warranty expires.
1.35v 5.0 is VERY good, grats.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10880698
14 hours ago, dave_k said:
Maybe for an Intel fanboy
I agree it's retarded that a H115i can't keep a sub-200W CPU below 90C, but the point is that 6-core Coffee Lake runs hot due to (as always) shitty Intel TIM. Worrying about temperatures below 100C means you'll lose a lot of sleep over nothing, tjmax exists for a reason, as does a user's warranty. Anyone who buys a 8700K should expect sky-high thermals unless they delid.
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10882912
8700K is over 200W for overall power draw when overclocked.
Even more when it's running hot (power leakage)
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/879868-i7-8700k-overclock-help/#findComment-10882945
