As far as possible.
CPU || Ryzen 2700x @ 4.3ghz  Motherboard || ROG Strix B450F  RAM || 16GB TridentZ 3600 B-Die  GPU || ASUS ROG Strix 1080Ti  Case || Thermaltake V71 RGB  Storage || Intel 760p 240GB + Intel 535 480GB SSD + 1TB WD 7200RPM HDD  PSU || Corsair HX850i  Cooling || Corsair H110i GTX  Keyboard || Corsair K70  Mouse || Logitech G502 Proteus  Sound || Bose Companion 5  Operating System || Windows 10 Pro
https://linustechtips.com/topic/879388-eth-mining-rig-help/#findComment-10875827
Well you should be buying blower cards so .5-.75”. Open air would be 2-3”. Depends on how many you are trying to stuff on a rack. Would rather buy a simple rack that’s holds 12 then build on myself.
https://linustechtips.com/topic/879388-eth-mining-rig-help/#findComment-10875882
