Hello everyone, ever since I got my gtx 1050 ti and have been able to play pubg, I've been having problems with the game starting and loading in. It will stay on the original screen and by the time my game loads I'm either dead or on the edge of the map where it's impossible to win. My specs are a 1050 ti 4gb, 4 gigs of ram, i5 2400. I've got a 500 gb hdd and an otiplex 390 case(I know the case is bad) please give me tips if anyone has any.
Also this doesn't happen in any games similar like fortnite. I'm really disappointed in this and I hope someone has a possible fix :D
https://linustechtips.com/topic/879205-pubg-problems/
have you checked any resource managers while you are playing? task manager for example to see if something is being over used, sounds very similar to my brothers old PC when we would play a large map on rust, which was caused by not having enough RAM, I want to say pubg is a 8K map? could be something similar to that.
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874016
A faster hard drive or SSD will speed up the load time when jumping into a game (the game must be installed on this faster storage in order for it to load faster. That's probably a given, but, better safe than sorry)
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874025
Just now, classic_ice said:
I'm not sure any since I'm not gonna be at my house with it for a couple of days, I'll be sure to tell you once I get back though @Himommies
if it's the preinstalled HDD then it's probaly 5400
Which in that case is probably the isssue
My life
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874048
Yeah, I thought it would most likely have been something similar to my hardrive, do you know by any chance if the optiplex 390 case can support ssd's very well? (Sorry, Ik I'm a newbie with this stuff) @TVwazhere
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874051
Since SSD's don't actullay move you can just stuff them somewhere
My life
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874055
Well I know it 'll fit, I'm just wondering if there are sata cables inside of the optiplex 390 case @Himommies  (I have the standard motherboard btw, I know it's a trash build. But it's the best I have atm)
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874074
there probaly might be sata power as they come in those long strands of 4 but probaly no Data cables
I would check before you make a purchase tho
My life
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874084
Just open it and see. If there's not one, borrow the optical drive's cable or get one. They're really cheap.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10874131
PC system requirements
Current system requirements as of December 2017 from Steam Official release.
  Minimum
OS 64-bit Operating Systems (Windows 7, Windows 8.1 & Windows 10)
Processor Intel Core i3-4340 / AMD FX-6300
GPU nVidia GeForce GTX 660 2GB / AMD Radeon HD 7850 2 GB
HD Space 30 GB available space
(Actual install size) ~ 13.9 GB
RAM 6 GB RAM
DirectX Version 11
https://linustechtips.com/topic/879205-pubg-problems/#findComment-10882250
