This is what I have in my newegg cart. I'm planning to build a $2000 gaming rig(before tax). I'd like some feedback on where I could maybe save a bit of money or recommendations on something you'd change. For now, I think I can do without an ssd I'll purchase those a bit down the line but if you have any recommendations for a good case that would be great. any suggestions for lower prices on other sites would also help. I'm not restricted to just newegg.
Thanks for the feedback guys. This is what I came up with. Do you guys have any suggestions for a case.
Edited by mregm
Updated config from sugestions
https://linustechtips.com/topic/878271-gamming-rig-help/
850W is a bit much, don't you think?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866059
Swap the memory for:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232394
or
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232476
I would highly suggest an SSD as well to save from having to do a re-install of windows down the line.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866064
Its more then he needs but both coffelake and that 1080ti have a pretty big draw if he he decides to overclock them, also leaves room for upgrades.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866066
9 minutes ago, mregm said:
Power supply is overkill, get a 650w unit for much cheaper
Consider a hybrid water cooled 1080 ti
that motherboard is overpriced and dumb, get one at the 120$ pricepoint
doesnt really matter , but get 2666 mhz ram
dont buy windows full price, get it for 5$ on ebay
get an ssd, maybe an 850 evo 500gb
EDIT: also change the aio with a h100i v2 from corsair
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866069
Just now, seon123 said:
550-650W would still be plenty for that
Oh 100%, like I said more then he needs, but if he adds a second GPU (Which obviously 0 point in doing, sli and xfire (Sorry MGPU) support is diminishing anyways) or perhaps more fans etc then having a little extra is nice. Although is that on sale right now?
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866082
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866388
51 minutes ago, Thermosman said:
8700k has to have a z370 motherboard, z270 won't work.
get 2666 mhz ram and save yourself some money
get the evga sc2 hybrid, its the same thing basically and cheape
as for a case, the NZXT s340 is a popular option and is good
I changed the motherboard to an
MSI Z370 SLI PLUS LGA 1151 (300 Series) Intel Z370 HDMI SATA 6Gb/s USB 3.1 ATX Intel Motherboard
and I was able to find and evgasc2 hybrid for $800
looks like I'm all set.
Thanks for the support man. I appreciate it
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10866556
I don't think you can use the EVGA kit with the MSI card you have in your list. IIRC it's meant as more of an upgrade kit for other EVGA cards. I'd also get a better PSU than you have listed. Something like a G2/G3. Check out the PSU Tier list and grab something from the first tier. As others have said you can't use the 8700k with Z270.
Also.....it's gaming. One M.
Welcome to the forum :)
Haha, that's quite a bit of overhead ;)
Eh, the more expensive boards do have some nice options, and they tend to look better. Some people care about aesthetics ;) Buying Windows for $5 is stupid. If you want a legit copy, pay full price. If you buy it for $5 you have absolutely no right to complain about anything Windows related.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/878271-gamming-rig-help/#findComment-10867592
