Damaged O-ring
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865295
7 minutes ago, MathiasVO said:
I've tried swapping my fittings, nothing changes.
Can you get an image of it so I can see what you are on about.
زندگی از چراغ
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865329
Try to identify at which connection point it' leaking. is it the pump-fitting or fitting-tubing etc etc.
Usually it' just a matter of something getting loose. but since you have the aluminium kit one should be wary to corrosion as another factor.
Can you list out your loop components including which coolant you used and whether you used silver kill coils etc. More information helps.
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865335
Just now, MathiasVO said:
https://imgur.com/a/3PxaQ
The left fitting on the pump leaks whenever it runs(the outlet)
That looks like a pump/res combo, try and find a new one to see if it fixes it.
زندگی از چراغ
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865352
It's has to be the pump since I've swapped the fitting, and the leak stays at the outlet.
I've also tried some different tube, doesn't make a difference either
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865353
please take a zoomed in photo of the leaking port without the fitting. Is there any chance you'e misthreaded the port and now it can't form a seal.
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865362
I'd rather not order a new one if I don't need to
Honestly that'll be the most stress free way of fixing this issue, it looks and sounds like the pump/res combo is faulty.
زندگی از چراغ
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865365
Can’t really see. Compare the threads to the other side. Look like it may have been over tightened.
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865414
2 hours ago, MathiasVO said:
Those threads are stripped out, it's only acetal so it only needs to be finger tight but there is no way to reliably salvage that unit.
-Topics Merged-
https://linustechtips.com/topic/878190-pump-leak/#findComment-10865715
