Sound card help.
Go to solution Solved by Sheldon_King,
Because the headsets don't need the amps (as I understand it, ATH-M50 should be 32Ohm), and teh quality of audio will not increase a bunch. The only real reason to go for a sound card is if you need features it has that the onboard does not have, or if you don't want to use an external amp for high impedance headphones. The quality difference is just not there. (Don't get me wrong, I use a low end PCIe soundcard, but only because my onboard is nonfunctional).
I  am looking for a sound card. Don't really wanna spend over 40$ And it can only be PCI-Express. Because my shitty mother board doesn't have just a PCI slot. Let me know what you think.
Case: Corsair white 600T | Motherboard: Asrock Z77 Extreme4 | CPU: intel i5-357OK oc to 4.3 | CPU Cooler: Corsair H100i | Graphics Card: Evga 660 Ti FTW signature 2 | Ram: Corsair Vengeance 8GBPower supply: ModXstream-pro 600W | SSD: Samsung 840 Series | Keyboard: Corsair K70Mouse: Corsair M65 | MonitorAsus VS228H-P 22-inch | 2nd Monitor:  Viewsonic 22 inch-LED 3rd Monitor: LG 32 inch tv | Mic: audio-technica AT2020 USB | Headset 1:  Audio technica ATH-M50s | Headset 2: Corsair Vengeance 2000.
https://linustechtips.com/topic/87805-sound-card-help/
I want that sound card. But my shit mother board cant use it i only got PCI Express slots.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190140
Couldn't you use the DGX instead? And you are not going to hear a difference unless your onboard is nonfunctional.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190167
Noticing that you have a corsair 2000 in your signature, I can tell you that you don't need one.
Do you not see my other headset... And i am asking what to get...
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190172
Why wouldn't i hear a difference?
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190180
The M50 won't need one either.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190190
Yes, and the recommendation is still not to get anything, Sound cards are notorious for high output impedance's which upsets the FR,  you should get better sound if not the same from your onboard.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190191
Dude i don't care i want one.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190199
Desktop <dead?>
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190203
So what do you recommend just a headphone amp?
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190208
Then waste your money.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190211
So just a headphone amp?
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190214
Maybe i got money to waste...
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190215
You don't need an amp. At all. Your headset is 32 ohm. If you had 300Ohm or the like you would need one.
DGx is a good low end unit, but you will not hear a difference between it and the onboard.
Desktop <dead?>
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190235
I have an asus H77 board, the onboard is fine for my 64Ohm headphones, and the SQ has been just as good as any sound card I have listened to.  If you have money to burn I'd either get another set of headphones or an O2/Odac.  neither are necessary but both are nice.
https://linustechtips.com/topic/87805-sound-card-help/#findComment-1190340
