If in ears are an option, I just picked up some jaybird x3's and they have great bass
23 minutes ago, detrivos07 said:
Alright, I am looking for a $250 usd or less pair of wireless headphones.  Something with good bass is preferred.  Any suggestions?
What is your use case for these headphones? Are you looking to use them for gaming? Traveling? Working out?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
5 minutes ago, detrivos07 said:
PC Gaming, and travelling
I would suggest that you take a look at the Bose SoundLink IIs. They have fantastic sound quality.
Desktop
Homelab
between soundlink and QC25 which one do you prefer?
i am afraid that the AAA batteries are too inconvenient.
If it is not broken, let's fix till it is.
2
QC25s are not wireless, while the Soundlink IIs are Bluetooth. The AAA batteries in the QC25s are only used for noise cancellation. I'm not a huge fan of the QC25s. They're great as a cheap noise cancelling option, but the battery life is quite poor. If you want wireless noise-canceling headphones, you'll need to step up to the QC 35s.
Desktop
Homelab
battery life quite poor as in those AAA batteries runs out of juice pretty fast?
The AAA batteries last around 35 hours according to Bose. I used a pair back in early 2016 and found they lasted about 30-32 hours. Though that doesn't seem bad, you need to remember to physically turn noise canceling off whenever you are not using the headphones. A few times I went to use the headphones and realized that I had left them on overnight, which will drain them pretty quickly.
Since the QC35s are wireless, noise canceling is controlled by whether or not they are turned on.
Desktop
Homelab
i see thanks. compare qc25 with soundlink which one sounds better to you?
I'd go with the SoundLinks. QC25s sound great when noise cancelation is on and can be a bit muted if you turn it off. SoundLinks sound good with Bluetooth and sound great if you use the included wire. If you don't care about wireless capabilities, take a look at the SoundTrue IIs. They're not as comfortable as the prior options, but have excellent sound quality for the price.
Desktop
Homelab
is there a physical button that I can turn off noise cancelling? or it can be done via software?
edit: also if I can get qc25 at 50% price point of soundlink, you think is it worth it?
QC35s have a button to toggle noise cancellation, QC25s have a switch. If you're worried about price, the QC25s are still a great value, regardless of its flaws. Just grab a pack of AAA rechargeable batteries along with it and you should be set.
Desktop
Homelab
