CPU: I7 4790K
Memory: 16gb ddr3
Storage: 4TB hdd
VideoCard: MSI Gtx 1080 TI
OS Windows 10
Well my question might seem wierd but i have some calculations that just wont work on the windows calculator (it gives a error of Overflow)becouse it would be to big.
So would it be posible to use for example the power of my GPU to do some masive calculations?
No idea if this is the right place to ask this question.
Sorry for my english.
https://linustechtips.com/topic/877959-using-pc-power-to-calculate/
What kind of calculations are you talking about here?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
7 minutes ago, Kylian said:
((256*256*256*)^1632)*((256*256*256*100)^1632)
google dosnt find any thing
Try using Wolfram Alpha.
1 minute ago, Kylian said:
seems to work kind of it dosnt input my full calculation but it it alrady a lot better then my windows calculator thnx
You can hit "more digits" to get more, but if you run the code(the little cloud button in the results), you can get the full value.
https://sandbox.open.wolframcloud.com/app/objects/4f12791f-6fcf-43e3-af1a-184ae7f4a33a#sidebar=compute
