I gather they can't be seen working before buying?
If not, then unless they are physically damaged you won't be able to tell really... it's a gamble, but a small one at $20. Has this seller listed these before anywhere, does he have any selling history that you can see?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/877658-motherboard-advice/#findComment-10860922
Does it come with everything else to make it work, like CPU, RAM and power supply? Or could you try it?
If yes then at least get into the BIOS and see if it detects everything. If no, look for visual damage. Btw it's ok for the mobo to not be clean. Back then it's normal for mobo to come out slightly dirty even when new.
Desktop benching:
https://linustechtips.com/topic/877658-motherboard-advice/#findComment-10860954
Yes ill be providing the cpu and hell be providing the psu and ram
https://linustechtips.com/topic/877658-motherboard-advice/#findComment-10860964
Then you can even bring a hard drive (forgot to mention above, cooler as well) with a clean install of Windows, with common test apps like Cinebench loaded, as well as HWinfo to make sure voltage and temps dont look weird.
Desktop benching:
https://linustechtips.com/topic/877658-motherboard-advice/#findComment-10861043
