Drain Port Problem
Solved by W-L,
5 minutes ago, coltonpan said:Hi guys,
So I setup a drain port just like how Jay did in his video on the reservoir/pump combo inlet with a T valve. However, when I do release the liquid in the system, only those in the reservoir would come out. How do I get the rest of the liquid to come out?
Check out this and you'll see what I mean. Jump to 11:24 mark. You'll see the liquid inside of the tube on top of the reservoir didn't go through. That's exactly what happened to me. Jay didn't show how he did the rest of the drain unfortunately.
In most cases you cannot get every last drop out but you can tilt the system and move it around to help remove as much as you can.
