Gpu riser problem
Go to solution Solved by Chronified,
14 minutes ago, techxnation said:
it shows TDP on a 1060 is 120w
That's for the reference model, pretty much anything that's made from a partner (Asus, MSI, Gigabyte, Zotac etc) has a "boost clock" that is enabled by default that raises TDP by a good chunk. Always include 20% power overhead on GPUs when mining.
I have a i7 4770k.
As for your CPU, if you check here your CPU only has 16 PCIe lanes, so....
gpu x2 = x8 + x8 cpu lanes
gpu x3= x8 + x4 + x4 cpu lanes
The CPU doesn't support 4x x4 at all. Sorry bub.
Unless there's been some sort of exploit to make them run in x4 by now, I think you're out of luck with that current CPU.
Maybe try using your integrated graphics and see if they'll at least mine in 1x8+ 2x4, maybe they just don't display when x4 is around. idk.
Using IGP during mining is best anyways since it'll take that load off of your GPUs.
As for the spare GPU, just grab a crappy dell from your local buy+swap for $40 and some adapters. Make sure PSU is 200w+ on core2 systems and 250w+ on any i model (most of them are). Those are the easiest, cheapest, and most scalable way to mine IMO due to parts availability and price.
I have a ASUS Maximus VII Hero.
Wanting to use 4  gtx 1060s
If i plug just the riser with one 1060 it works.
2 gpus on the mobo works. But if i then try to add another gpu via a riser, does not work.
Using a CX750m psu
Tried 4 diff risers.
Checked all connections.
Enabled 4g decoding.
Tried pci gen 1/2
https://linustechtips.com/topic/876649-gpu-riser-problem/
First, state the obvious: If you're running SLI that's not gonna work. 2 at a time only.
Second: 750w for 4x1060? You're funny lol.
Those GPUs pull about 700w combined as it is, without any OC or the rest of the system on top (CPU, storage, fans etc). Your system is likely saving itself at the power spike during startup by not letting you do that.
Use the good-old paperclip trick on a 1 or 2 spare PSUs to see if the system works with 2 GPUs on another/other PSUs before you upgrade.
Third: LGA 1150 is starting to age greatly, I wouldn't be surprised if your CPU just doesn't have enough lanes to support 3 or 4 1060s at a time (don't certain 1060/70/80 cards not work at all in x4?)
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/876649-gpu-riser-problem/#findComment-10852713
Hey thanks for the reply. This was meant for mining not SLI as I understand the GTX 1060 does not support SLI. I have a i7 4770k. I thought it would of worked on my PSU as others said they run 4 etc on a 750w PSU as it shows TDP on a 1060 is 120w
https://linustechtips.com/topic/876649-gpu-riser-problem/#findComment-10852755
I have a i7 4770k.
Edited by Chronified
corrections
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
https://linustechtips.com/topic/876649-gpu-riser-problem/#findComment-10852780
