dp and hdmi dont work
Solved by emosun,
plug the one display port monitor in that you want. then restart the machine so it will detect the monitor while windows is loading.
you'll also know if the ports and cards and monitor are working if the post screen is shown before windows loads.
Featured Topics
1
Shane Martin ·
Posted in Displays2 -
5
INotPablo ·
Posted in CPUs, Motherboards, and Memory2 -
PatRed ·
Posted in New Builds and Planning8 -
Manv2000 ·
Posted in Troubleshooting0 -
8
QMalcolm ·
Posted in General Discussion3
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
