Hyper 212X help mounting.
Go to solution Solved by W-L,
23 minutes ago, Princess Cadence said:
So I have done all that seemed right, though when I try to sit every thing in place the thingy to screw in feels too high and when I get one down the other gets up and I feel I have to do far too much pressure to get it in place... any helps?
@MageTank any ideas? z370 d3h mat
Make sure the center bolt is tightened down where the bracket is down against the heatsink block aligning with the dowel pin. After you can align it with the mounting holes and just tighten down the mounting bolts give as they are just spring loaded.
@MageTank any ideas? z370 d3h matx
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/875212-hyper-212x-help-mounting/
Yes besides my brother told me that you should really make pressure I wasn't used to it, good thing is mounted now ^^
Personal Desktop":
