Water cooler capacity
Go to solution Solved by Crunchy Dragon,
Yes. FCLGA1151 is the same as LGA1151. Not to mention all the coolers that support LGA775 will support LGA1151 as the mounting points have not changed.
https://linustechtips.com/topic/874383-water-cooler-capacity/#findComment-10832322
I have an 1156 board, theres a reason it also has 775 mounting points.  They are not compatible.  All 115x are good to go but not 775/771
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/874383-water-cooler-capacity/#findComment-10832342
