Motherboard's Audio Chipset
ABehery
I have recently built a new PC with Asus TUF B350 Gaming Plus, and the onboard sound quality is not satisfying to me (The Iphone's output way louder and clearer than the mobo's), Is there a way to correct it and make it better? Should I get an amp? If so, could you recommend me a budget value one?
Thank you!
are you connecting to the back of the motherboard or using a case's front panel?
Option 1: update audio chipset drivers if you havent already
https://www.asus.com/ca-en/Motherboards/TUF-B350M-PLUS-GAMING/HelpDesk_Download/
http://dlcdnet.asus.com/pub/ASUS/mb/01AUDIO/Realtek_AudioDriver_Win10_V6018158_20170823.zip
Option 2: you could just buy a simple 2.0 channel PCIe soundcard
Photography / Finance / Gaming
both the case's front panel and back of motherboard sound the same, upgrading to this driver made no changes :(
hmm alright
DFX / FXSound is a software solution you may find acceptable, if not cheap.
https://www.fxsound.com/webapps/premium
I use it on my Laptop and Desktop to get some extra boost to my outputs.  It can effectively increase your output volume, and has nice built in equalization as well.  If you push it too far, it can become distorted, so it takes some playing around, but it is well worth it, IMO.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
As a semi-audiophile I find onboard audio unbearable.  I use a USB DAC for all of my audio, specifically the Sound Blaster X7.
Will give it a shot, thank you!
Way too pricey for a semi-audiophile :D
as a x7 user too its not as superior in sound as you think on dac side
that doesnt take much, x7 selling point is it multi abilities and sbx(which I love for many games)
i would use onboard if I could answer phone calls easily, sbx, and power passive speaker too
dac isnt the issue here dac accuracy is what to x7 accuracy?
1 hour ago, huilun02 said:
Get an Audioquest Dragonfly and never have deal to deal with bad sound ever again.
oh another overpriced thing I had for awhile
Thank you!
now if you are getting interference then thats a big reason to go external
made my zxr external before I went with x7
i'd like to know more about your issue than jsut saying this or that
Jesus this, Moses that, Abraham hit me with a wiffle ball bat
little nicky lol
little nicky lol
Sound is a bit muffled but that is not the problem, the output is very weak even when I turn the volume all the way up, very noticeable difference between the iphone and the PC, specially regarding the bass.
is windows configed  for 5.1?
I know if go thru that and choose 5.1 on anything its fucking weak
Nope, Stereo.
Just now, pas008 said:
ok good now what headphones are you using
Sony MDR-XB450
2 minutes ago, ABehery said:
Sony MDR-XB450
those can be driven by anything
not trying to be a dick here though
which port did you plug them into in the back?
Exactly my point, Line out.
pink or green?
try the other
pink or green?
try the other
Green, tried all 3 unfortunately.
10 minutes ago, pas008 said:
did you install the drivers?
I did :/
Just now, ABehery said:
I did :/
now we narrowed down the problem onboard is failing you
you have many options
rma with great reason but will give you downtime
I'm never a fan of downtime
anything and everything will power those headphones
including my kids leapfrog crap but not the point
what comes to mind is what is your budget with the thought of your sound quality
Downtime is a no no for me too, the most budget/value, nothing too fancy.
can you try them on others setups?
i'm not a fan of making you spend cash on trial and error considering you said they work fine with  other products
887 chip is fine but onboard can be an issue in those days considering they didnt have separate ground
They worked fine on my 6 years old dell laptop, the sound is not bad, its just less powerful than my iphone which makes me mad.
