13 minutes ago, IziBartek said:
I tried remounting it 3 times now. Nothing's improved.
You sure its tight? Only way you get that high idle temp is that cooler isn't mounted tight. Even with broken pump you should get lower temps, around 60C IIRC.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/873293-help/#findComment-10823124
