I would say no, since 10.9 > 10.7, but it might squeeze in with such a small difference. However I wouldn't recommend it, and the h500p is a terrible case imo due it's crap build quality and terrible airflow
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821545
That’s what she said
yeah, it should fit.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821548
don't buy that shitty case
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821552
5 minutes ago, Straussy said:
Whats wrong with it?
Trash build quality and medicere performance
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821564
It hasshit airflow and terrible build quality. The top and front panels will pop out with the slightest touch and the tg side panel has a sort of gap due to the way its secured. I recommend checking out gamers nexus review of it on youtube
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821565
10 minutes ago, Straussy said:
It should meaning the .2 shouldnt matter to much?
Correct.
42
also,
My build:
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821568
You could take a look at the H700i, Dark base 700 or the Evolv ATX Glass. It really depends what you want. I personally am not that bothered about cases with tons of airflow, I use the dark base 700. RGB that syncs with any motherboard,  sound dampening foam, usb 3.1 type c gen 2 at the front IO, silent wings 3 fans (best on the market pretty much) and one of the cleanest interiors ever.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821606
but the case looks nice so who cares
System
  • CPU
    Ryzen 1600x
  • Motherboard
    ASUS ROG STRIX B350-F
  • RAM
    16gb trident z RGB 3000 mhz
  • GPU
    1070ti Msi Twin Frozer
  • Case
    CoolerMaster Maker 5
  • Storage
    850 Evo 250gb Qty:2
  • PSU
    EVGA SuperNova G1 Watt:650
  • Display(s)
    1 Acer 24in 60hz, 1 Acer 24in 144hz
  • Cooling
    NZXT kraken x62 rev2, NZXT AER RGB 140mm Qty:5, CableMod 30cm RGB strip Qty:2
  • Keyboard
    K551 VARA by Redragon 104 Key RGB
  • Mouse
    Redragon M601 Gaming Mouse
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821622
50 minutes ago, Straussy said:
So i want to use this case, the CoolerMaster H500 with the ASUS ROG Rampage Vl extreme motherboard but the board is 12 x 10.9 but the specifications of the case say it holds 12 x 10.7, So will it fit?
what cpu and gpu are you buying
System
  • CPU
    Ryzen 1600x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
    850 Evo 250gb Qty:2
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
  • Mouse
https://linustechtips.com/topic/873161-will-it-fit/#findComment-10821641
