Some help in my monitor wars
Hunlight
Hello,
So after ton of help from this forum (btw thanks all for the help) I sticked with qhd widescreen monitor 1080p but with 144hz, but unfortunately last one was sold out and in others shops around price for it like 70-80 eurs higher its not worth it.
So the question what about 1440p qhd widescreen but 60Hz (mby 75Hz if OC but I wont bother with it) its model from LG costs arround 570-630 eur here. I cant afford to pay more better if less.
52 minutes ago, Hunlight said:
Hello,
What is your question do you want a 1440p 60Hz display? https://de.pcpartpicker.com/products/monitor/#r=256001440&sort=price&page=1&H=60,240
or something else?
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
Where are you from?
You should be able to get 1440p IPS 144Hz/165Hz for around €600.
2 hours ago, WereCat said:
Where are you from?
nah impossible cant even find one monitor with 1440p and 144Hz. Im from Lithuania btw.
shop Im using (almsot cheapest but fastest delivery) is skytech.lt
Also now Im looking on cheaper thing its not widescreen but its 4k display for 390 eur, 32" amva
