Need Help for a case
Go to solution Solved by TVwazhere,
2 minutes ago, Selkom said:
Hello !
Building a new pc soon for streaming  !
I was going for the Air 540 cause i will doing lan and she looks portable !
So what are you guys advice for case ?
The config :
https://pcpartpicker.com/list/CwmqKZ
The air 540 is a very big case. You can get a much smaller case, especially if you swap the Corsair RMX PSU for an EVGA G3, and get a Fractal Design Define C; a case 2/3rds the size of the air 540.
Hello !
The config :
https://linustechtips.com/topic/872939-need-help-for-a-case/#findComment-10819582
Just now, Selkom said:
I was going for the air 540 cause she had two 140mn fan at the front would the Fractal Design Define C have good airflow ?
It has very decent airflow, the Air 540 will be the best, but its probably a difference of about 100% (air 540) to 85%, nothing really noticeable. The Define C will be quieter, however, because it has sound dampening foam. And as previously mentioned, much smaller (means it will be easier to transport
https://linustechtips.com/topic/872939-need-help-for-a-case/#findComment-10819604
Oh Yeah just a quick question out topic should i put the kraken x62 fan in or ou the case ?
The position of the fans doesnt matter. Whether you do push or pull, you'll get the same temperatures
https://linustechtips.com/topic/872939-need-help-for-a-case/#findComment-10819606
Ok thanks you, for your help !
I Guess i will go with the fractal !
Love this Forum !
https://linustechtips.com/topic/872939-need-help-for-a-case/#findComment-10819621
