SLI help...
7 minutes ago, DarkFireGuy said:So I've got this rig:
GeForce GTX 960
Inteli5-4690k 3.5GHz
Board : MSIz97-g45 Gaming
8gigs ram and some other stuff
And I want to add a 1080 ti but don't know how to do it. I need a list of parts and some instructions specific to my parts. Any help is appreciated!
Additional question: are there any inexpensive alternatives for the 1080 ti with comparable performance.
Is this a shit post or?
I'm going to give the benefit of the doubt here.
In order to SLI GPUs they must be of the same chipset, for example 2x GTX 960.
Also, what motherboard do you have? How many PCI-E x16 slots does it have?
Something you can do is insert the GTX 1080TI and use the GTX 960 as a physics card. However in modern day that's kind of a useless practise. (In some cases hindering performance)
As for the alternatives to the GTX 1080TI.
In short; No, not really AMDs competition is slightly cheaper However it requires more power and less performance.
