do you already have the os and monitor?
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809792
Australia right? let me fix that for you just a second.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809793
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($485.00 @ Umart)
Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard  ($228.00 @ Shopping Express)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($259.00 @ PCCaseGear)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($194.00 @ Shopping Express)
Video Card: Gigabyte - GeForce GTX 1070 Ti 8GB Video Card  ($669.00 @ Shopping Express)
Case: Cooler Master - MasterBox Lite 5 ATX Mid Tower Case  ($64.00 @ Shopping Express)
Power Supply: XFX - TS 550W 80+ Gold Certified ATX Power Supply  ($99.00 @ PCCaseGear)
Total: $1998.00
Generated by PCPartPicker 2017-12-11 21:45 AEDT+1100
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809802
CPU Cooler: Cooler Master - Hyper 212X 82.9 CFM CPU Cooler  ($44.30 @ Skycomp Technology)
Motherboard: Gigabyte - Z370M D3H (rev. 1.0) Micro ATX LGA1151 Motherboard  ($181.50 @ Skycomp Technology)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($229.90 @ Newegg Australia)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($79.00 @ Mwave Australia)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.00 @ Shopping Express)
Video Card: Zotac - GeForce GTX 1070 Ti 8GB Mini Video Card  ($699.00 @ Scorptec)
Case: Cooler Master - MasterBox Lite 3.1 TG MicroATX Mid Tower Case  ($59.00 @ PLE Computers)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($118.00 @ Shopping Express)
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor
Total: $1954.70
Generated by PCPartPicker 2017-12-11 21:47 AEDT+1100
Personal Desktop":
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809803
Total: $1998.00
what about cooling
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809810
1 minute ago, Oskar Mcfarlane said:
what about cooling
the stock cooler that comes with the 8700 will work just fine.
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809815
are you planning on overclocking? if not stock cooling should work just fine aslong as the case you use has a decent intake and exhaust fan
current build and total cost   http://linustechtips.com/main/topic/150083-thrift-shop-build/
I apologize for my crappy English I'm American
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809817
Just now, TSL said:
Just barely... ;)
but it'll work, and if the temps get too high he can just get a cryorig M9i for $30 to deal with temps.
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809822
6 minutes ago, Alex Colson said:
I think that CPU Comes with a Stock Cooler
Believe me I used to think like that until I live an year with the stock cooler on an i7 6700... it ain't worth it... temps around 70C+ when stressing it and bloooody noise that I still nightmare about, as I suggested the 212X would solve the issue for decent costing.
5 minutes ago, ThomasAJ88 said:
And i would buy the 8700K.
Gaming is all about the clockspeed when it comes too CPU's.
Nope (already set the time):
the i7 8700 already has a really high clockspeed and even so that does not matter as much as it used to because we're finally away from the limiting 4 cores era, 6 cores gives a lot of breathing room in a world where games are actually decently optimized for multi-threading now, and regardless at 1440p we're already GPU bond with a 1070 Ti, overclocking the i7 8700k would make this build way over its budget for zero performance increase, try again.
Personal Desktop":
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809829
is having the one stick memory worse than two? or doesnt matter
You lose dual channel going with a single stick.
Personal Desktop":
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809830
dual channel will help with performance abit, depending on the programs. doubt you'll need more than 16gb and you still have 2 slots for expansion so might as well go with a dual channel kit.
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809836
oh and it gets hot in aus so a cooler is a good idea
if you really think you need it then get an m9i for $30, but i'd see if the stock cooler is good enough first before shelling out extra for a cooler.
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809842
Total: $1954.70
you prefer TN panels over IPS fpr gaming ?! i mean the difference in response time is not really a big deal to ignore the better quality image in IPS panels ! what do you think ?
https://linustechtips.com/topic/871949-build-help-suggestions/#findComment-10809913
