So I recently just bought an AMD A10-7860K and noticed that there is no change in performance from my previous cpu which was an AMD Athlon X4 860K. I typically play Garrys Mod a lot and thats where i notice it a lot. I do have Windows 10 Pro but am not quite sure if I still need to install some type of driver for my cpu. I know it isnt my gpu because its a EVGA 980Ti SC and I have 16gb of HyperX Fury Ram. Please let me know if I need to install other drivers or something else in-order to get better performance. Links will help also. Thnks in advance!
Setup Currently:
Case: EVGA DG-76
Mobo: ASUS
CPU: AMD FX-8350K 3.7Ghz
RAM: 28GB HyperX Fury
HDD: PNY 120GB SSD & WD Blue 1TB
GPU: EVGA GeForce GTX 980Ti SC (Reference model)
PSU: EVGA SuperNova 750W G3
Heatsink: NZXT Kraken x52
Peripherals:
Mouse: Logitech G502
Headset: Logitech G930 Wireless
Keyboard: Logitech G810 RGB Romer-G
Monitors:
AOC 19"
https://linustechtips.com/topic/871883-help-with-cpu/
there is no performance difference because those CPU's are basically the same...and both arent anywhere near fast enough to properly feed a GTX 980ti in games.
http://cpu.userbenchmark.com/Compare/AMD-A10-7860K-APU-vs-AMD-Athlon-II-X4-860K/m83781vs3265
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809095
ur cpu is bottlenecking the hell out of the 980 ti, if you need to upgrade to a proper setup, please let us know ur budget.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809111
i will repeat what i_build_nanosuit have said
the reason why you dont feel any difference from the two CPU/APU
is because they are internally produced the same die/wafer in the manufacturing process
the A10 has the iGPU part while the 860K is a cut down version of the A10 without the working iGPU during the binning process
during binning
they will pick the working APUs and label them as A10 and goes down the line as the grade drops
A8, A6 and A4
and the APU without any working iGPUs will become the Athlon X4 CPUs
hence you see the 860K which is the A10 non-iGPU version.
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809113
I have been looking at i5-2400's for around $50. I really just need a better cpu and mobo that will eork with ddr3.
Setup Currently:
Case: EVGA DG-76
Mobo: ASUS
Peripherals:
Monitors:
AOC 19"
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809137
see if u can find a 2500k/2600k for 70dollars, a 4.5 2500k will bottleneck the gpu much less than the i5 2400.
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809142
I found a 2500k for $70. Are you saying that I should overclock the cpu to 4.5?
Setup Currently:
Case: EVGA DG-76
Mobo: ASUS
Peripherals:
Monitors:
AOC 19"
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809176
yes, either a 2500k, 2600k, 3570k, or 3770k overclocked to 4.5ghz would be suitable for that card.
Just wanted to list all the options since you are buying used.
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809187
Do note that you will also need P67 or Z68 (iirc) or Z77 chipset motherboards to fit the processor and support overclocking.
CPU/ CPU Cooler: i7-6700K - 4.5GHz with Noctua DH-15S | Motherboard: ASUS Z170 Pro Gaming | RAM: 2x8GB Corsair Vengeance LPX DDR4 2400MHz | SSD: Samsung 850 EVO 250GB M.2 | HDD: Western Digital Caviar Blue 1TB 7200 RPM | GPU: Zotac GeForce GTX 1060 Amp! Edition | Case: Corsair 400C | PSU: FSP Aurum S 650W | OS: Windows 10 Pro 64-Bit
Monitor: BenQ GL2460HM FHD | Speakers: JBL Pebbles | Keyboard: Logitech G710+ | Mouse: Steelseries Sensei 310
https://linustechtips.com/topic/871883-help-with-cpu/#findComment-10809277
