Reached 60 and counting rendering a 1080p60 vid, scared for chip safety and system safety. Running stock clocks and cooler with a 1700. Rendering as you read this. Over central heating, I couldn't hear the fan but it was probably running at 100% the whole time, measured temps with CPUID and it peaked near 61
Edit: Finished, and having said all that it was an absurdly fast render time compared to my old Intel 4690
https://linustechtips.com/topic/871857-safe-ryzen-temps/
Assuming that's 60 centigrade or Fahrenheit you're absolutely fine, you could even consider it cool. Modern processor's will never let them selves reach an unsafe temp, but rather will throttle their performance to keep the temperature in check. That would happen around 90+ centigrade.
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10808837
If you're looking at CPUID HWMonitor's Package Temperature, you're completely fine in the 60s. That's where my 1600 overclocked to 3.8 sits at full load. I generally recommend not exceeding 80c while overclocking, but you're perfectly fine.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10808866
agreed, anything 80C and lower is just fine, though upper 70C's is getting mighty toasty for long term loading.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10808867
Centigrade
Well it rendered basically at real time, and it doesn't cross 50 when gaming in any case. 60 is absolutely fine, then?
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809070
Do you reckon I could invest in a good aftermarket cooler within a, say, $50 budget, and add some Arctic Silver 5 I have lying around to shave some degrees off despite being in the safe zone? It's relatively cold this time of the year, and my room gets rather toasty in the summer.
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809079
What cooler do you have? I'm on the standard wraith one but my 1700 at full load on stock clocks peaked at 61, which doesn't sound right if your 1600 overclocked a fair bit reaches the same at full load, right? I have a pretty similar build to yours, same motherboard, an EVGA 1070ti, a couple of exhaust fans and nothing else of concern with the temperature in the case, which is an S340 elite
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809088
I use the Noctua cooler in my signature. When I used the stock Wraith Spire at 3.8GHz, my temperatures reached 80+ during Prime95 stress test. I opted to purchase the Noctua Cooler so I could attempt 4GHz at higher voltages while keeping the temperatures within safe ranges (was unsuccessful at hitting 4GHz).
Your temperatures on the stock cooler are perfectly fine and are expected. You have nothing to worry about.
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809104
3.5 or 3.7 is the sweet spot for efficiency on the 1700, you can probably do 3.5 on stock voltage. 3.7 if u bump the voltage and it barely uses 100w on full load, temps should be just right. above 3.7 the power drain and the temperature rises exponentially. I'd stick with the stock heatsink, thats the whole point of ryzen.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809120
Ryzen 1600 here. Stock speed, stock hsf.
35c no load, 60c max load.
Room temp 27c.
Same result with hyper 212.
I assumed you never had core 2 processor which idle at 50c.
this is very cool.
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10809621
absolutely.
System specs:
https://linustechtips.com/topic/871857-safe-ryzen-temps/#findComment-10810258
