Im planning my first build and im looking to build a pc that will run way over or at least 60fps win my limited budget.
I've picked these parts so far and i need a good gpu to go alongside it
CPU: Ryzen 5 1500X                                    approx £190
MOBO: MSI AMD B350 Mate                       approx £100
RAM: Corsair vengance LPX 2x4GB          approx £100
MEMORY: WD 1TB Blue                               approx £40
        ____________ +
  So far:        £430
Im saving up and it will probably be a year or two before i actually am able to afford this
>Should i wait until i have a stable amount of money in my pocket to pick parts?
£800 is a bit exessive to me however i've been eyeing the Sapphite Radeon Nitro+ 8GB
 should i pick this gpu
https://linustechtips.com/topic/871677-my-first-build/
Just now, SpiritOfTheGods Skinhub.com said:
  So far:        £430
You should wait. Zen2 was rumoured with a leak earlier today which will launch next year, so you'll probably have better cpu options.
Do stick with the 580 though.
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/871677-my-first-build/#findComment-10807351
Although im only contemplating my GPU choice am i misinformed to assume that this CPU will be quite more expensive than my APU and will therefore break the bank?
https://linustechtips.com/topic/871677-my-first-build/#findComment-10807367
5 minutes ago, SpiritOfTheGods Skinhub.com said:
Ya don't buy anything in parts
really if you're just gaming at 1080p 60hz Raven Ridge APUs should be coming, likely won't need a GPU to get some gaming done.
https://linustechtips.com/topic/871677-my-first-build/#findComment-10807370
If it's gonna take you that long to save up enough money for a reasonable PC, I'd say it's pointless to look at parts for it yet. Pretty much anything can happen in a year, so you're better off just saving up money, then after a year see what parts are a good buy at that time.
https://linustechtips.com/topic/871677-my-first-build/#findComment-10807375
        ____________ +
  So far:        £430
In two years the market will probably be very different so I wouldn't bother planning parts yet. Just start planning when you have your money ready
https://linustechtips.com/topic/871677-my-first-build/#findComment-10807418
