I am having a bit of a problem choosing a case on amazon. The one that originally was looking to get never came back instock so i got to choose a different one. I am looking for a black case ( red accents optional but only red) with good airflow. I don’t want a case that will choke the front case fans. A see through side panel is also a must. I am putting in an ATX motherboard. The most i want to spend is about £80. Any suggestions?
https://linustechtips.com/topic/871598-need-help-choosing/
id go for the Silverstone RL06 if you want good airflow and red accents, its a pretty good case
Builds:
https://linustechtips.com/topic/871598-need-help-choosing/#findComment-10806638
Can you remove the front case fan that are pre installed. I read a comment on amazon about the case and someone said that the front fans gets pretty loud under load.
https://linustechtips.com/topic/871598-need-help-choosing/#findComment-10806652
yah you should be able to remove those no problem, or you could just set them to a lower RPM where the noise isnt too much :)
Builds:
https://linustechtips.com/topic/871598-need-help-choosing/#findComment-10806654
Good to know, thanks. It looks like a good case, if i can’t find a better case than i will get this one. Have you had any personal experience with this case?
https://linustechtips.com/topic/871598-need-help-choosing/#findComment-10806666
no personal experience but i have seen good reviews for it and looking at gamers nexus temperature charts its the top performer
Builds:
https://linustechtips.com/topic/871598-need-help-choosing/#findComment-10806676
