Hello,
im about to build my first PC rig, i tought about an i5-8600k and GTX 1080 build. Due to aviability issues with the I7-8700k.
Im mostly gaming on it with maybe some small Deep Learning in between. I would like to play 1080p / 144Hz on all games on max settings and one Monitor.
Im mainly playing Warframe, Planetside 2 and Evolve stage 2.
Budget is around 2500-2600CHF (Swiss Francs) at https://www.digitec.ch/en wich is probably the cheapest merchant in Switzerland.
I already got a Roccat Kone EMP for a Mouse, Monitor is going to be Asus -VG248QE, Keyboard Cooler Master L.
So, is everything Compatible and will there be Any Bottlenecks?
here the lists:
PcPartPicker: https://pcpartpicker.com/list/yVyMqk
List at merchant: https://www.digitec.ch/de/ShopList/Show?shopListId=CAEB39D487ED1FEE0894F72DB989016F
https://linustechtips.com/topic/871187-first-build/
You dont need m.2, get an hdd + ssd, or just an ssd
I dont think those games are that intense, so mabye a 1070/ti?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/871187-first-build/#findComment-10802961
1080p is almost a waste with this budget
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/871187-first-build/#findComment-10802964
1 minute ago, _SAITAMA_ said:
Can you add like 50-100$ to your budget? If so get theese:
https://pcpartpicker.com/list/6cvMqk
Get a 1700 over 1800x and OC to same level.
OP is just gaming at 1080, the 1700 will give no advantage.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/871187-first-build/#findComment-10802965
I'd go for 1440p, but maybe OP is one of those weirdos who swears by 144Hz, and says that 60Hz looks like shit (hence why he's spending so much on a 1080p build).
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/871187-first-build/#findComment-10802995
Get some cheaper ram as 3600 MHz is hella expensive (3000 or 3200 is fine), and a normal 500gb sata ssd should be ok. The case is a bit expensive and I would get a better psu (look for evga g2/G3, corsair RMx/rmi, whisper m, and focus plus gold).
I think if you went for a cheaper cooler, motherboard, ram, and case you might even be able to squeeze in a 1080 ti.
I personally don't see the point of an R7 CPU for 1080p gaming.
Plus 1800x is bad value compared to a 1700
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/871187-first-build/#findComment-10803035
or you know
this
PCPartPicker part list: https://pcpartpicker.com/list/f6bJsJ
Price breakdown by merchant: https://pcpartpicker.com/list/f6bJsJ/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($405.98 @ Newegg)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  ($148.49 @ SuperBiiz)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($159.99 @ Amazon)
Memory: Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2666 Memory  ($173.49 @ Adorama)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($139.99 @ B&H)
Storage: Hitachi - Deskstar 2TB 3.5" 7200RPM Internal Hard Drive  ($55.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB Black Edition Video Card  ($739.99 @ SuperBiiz)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($86.99 @ SuperBiiz)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.98 @ Newegg)
Monitor: LG - 34UM88C-P 34.0" 3440x1440 60Hz Monitor  ($589.00 @ Newegg Marketplace)
Keyboard: Corsair - K65 RGB Wired Gaming Keyboard  ($84.96 @ Amazon)
Total: $2650.85
Generated by PCPartPicker 2017-12-09 09:59 EST-0500
My life
https://linustechtips.com/topic/871187-first-build/#findComment-10803051
