So I booted my computer after I had pressed update and shut down and the colours began to look very strange, it’s as if someone put a negative filter on it, as you can see from the photos below that is not how windows should look like, does anyone know how to fix, I have reset my pc and I also updated my graphics card drivers but the problems still remains E96F0ED5-8AA5-4AD7-9510-0A2AE240C4C9.thumb.jpeg.2ae6fcf28fcc355468bc0112e6ce6f06.jpeg
https://linustechtips.com/topic/870051-help-me-please/
Uninstall and reinstall GPU drivers.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/870051-help-me-please/#findComment-10792681
4 minutes ago, SamGuve said:
How do I do that
Use a program like DDU, which will fully uninstall your GPU drivers and reinstall them after that.
Also, if possible, try using another cable to see if that does anything or a different port on your GPU if possible even.
https://linustechtips.com/topic/870051-help-me-please/#findComment-10792705
1 minute ago, SamGuve said:
Will using the device manager and uninstalling the drivers there do anything
When you reboot the computer, it'll just look for the driver again and reinstall them. Might help, might not.
DDU uninstall is the best option. It completely removes the driver files from the registry, so you'll have to reinstall the drivers manually from the setup files
https://linustechtips.com/topic/870051-help-me-please/#findComment-10792766
54 minutes ago, SamGuve said:
The problem has came back as I was installing the GeForce app the colours reverted back to they way they were before I uninstalled the drivers, it made the tone that happens when I connect a usb device so I think it reinstalled the drivers by itself
Did you use DDU? That is the important part here. Fresh, clean driver install
https://linustechtips.com/topic/870051-help-me-please/#findComment-10793096
