mount a CM Glacer 240L in the front and install nf-f12 everywhere in the case(top, bottom, back, and front)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/86926-cooling-for-define-mini/#findComment-1179629
What would be an ideal cooling solution for the Define Mini? Including case fans and cpu cooler. I've got a 3570K in there with EVGA 670 FTW. Either air or aio water. Also including where the fans should be placed. Silence is a priority :) Thanks!
H100 (50$ tiger direct)
Nb eloops in front, rad in top, eloops pushing on rad. Don't use rear exhaust. Can't remember if the bottom has a fan, if it does use a eloop there.
Anyone whom says nf12's are to be ignored at all times. They are noisy and are only good for high static pressure.
Also, another good option would be Silverstone ap123's in the front and bottom. They are very quiet with amazing directional airflow. They would cool your graphics card well
Edit: plug the side and rear exhaust with the foam gaurds that comes with the case. That will help sound levels. Also, make sure you have enough ports to control in your board, or that you get a USB controller like http://www.frozencpu.com/products/13696/bus-271/Aquacomputer_Aquaero_5_LT_USB_Fan_Controller_Liquid_System_Controller_53095.html there are probably better controller modules, but don't get one you mount in a drive bay
https://linustechtips.com/topic/86926-cooling-for-define-mini/#findComment-1184316
Just get a NH-u12s.
https://linustechtips.com/topic/86926-cooling-for-define-mini/#findComment-1188860
Put BeQuiet! fans everywhere and run them at 7v for true silence. As for CPU cooler, Get a Prolimatech Megahalems and put BeQuiet! Fans on that. And to whoever said NF-F12s; they are pretty loud.
"The unexamined life is not worth living" - Apology 38a, Socrates
https://linustechtips.com/topic/86926-cooling-for-define-mini/#findComment-1189048
I have that case, and by specs are in my sig. I have all 5 fans slot filled, top exhaust, rear is h55, front and bottom intake
only time it's sort of loud is if I ramp the GPU fans up
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/86926-cooling-for-define-mini/#findComment-1189729
