I am planning on building a new gaming PC, I am trying to keep my budget around 1100 US dollars, but currently I'm looking at $1215, can I get some suggestions on what to change?
Specs:
Case - Phanteks Eclipse P400s
Motherboard - MSI Gaming Ryzen B350 PC MATE
CPU - Ryzen 5 1600x (Only because it was only and extra $20 on amazon vs the 1600)
Graphics - EVGA GeForce 1070 SC2 Black Edition
RAM - Ballistic 16GB DDR4 2666
Power Supply - EVGA 500 B1
Storage - Samsung 850 EVO 250GB SSD
Cooler - Cooler Master MasterLiquid 120
Any suggestions are helpful.
https://linustechtips.com/topic/868859-gaming-pc-build-help/
Looks good to me. I personally would get a better power supply and i think you can fit a 1070ti if you change somethings. I personally always suggest buying a cheap case so the money goes into performance but anyways... would defiantly get a better psu tho.
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10780936
No. none of this
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10780937
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.98 @ SuperBiiz)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard  ($90.98 @ Newegg)
Memory: *Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($176.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.99 @ B&H)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($41.89 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($469.99 @ B&H)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Cooler Master - 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $1169.80
Generated by PCPartPicker 2017-12-03 21:48 EST-0500
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10780951
I agree what you said about the case but I am personally willing to go a little higher on the case just for the reason of how good it truly looks and I have Phanteks case in my current PC and I like the build of it, the cable manage and they also give a lot of upgrade space in the future. But I will do some switching and if I can't squeeze in a 1080ti. Thanks for the feedback.
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10780993
Total: $1169.80
I think Im going to take you up on a couple of these products, thanks for the help.
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10781039
Consider all of them. The 1600 can be overclocked to 1600X speeds easily with the stock cooler, this motherboard has a better VRM, I included a 1070 Tim and the PSU is on a great sale.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/868859-gaming-pc-build-help/#findComment-10781222
