I have a voucher for Currys PCWorld in the UK and I'm thinking of buying a modular power supply. I have also got a 10% staff discount
I'm going to be running a Ryzen 5 1600 and for now a GTX 960 but that'll probably be replaced with a GTX 1160 when it comes out.
It's between these 2 because of the price. Are they decent or should I spend my voucher on something else?
https://www.pcworld.co.uk/gbuk/computing-accessories/components-and-upgrades/power-supplies/coolermaster-g550m-modular-atx-psu-550-w-10118701-pdt.html
https://www.pcworld.co.uk/gbuk/computing-accessories/components-and-upgrades/power-supplies/coolermaster-g650m-modular-atx-psu-650w-10118637-pdt.html
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/868178-cooler-master-psu-options/
Just now, RKRiley said:
I would rather have it modular cause I'm getting a windowed case and I hate how messy the case I have now is with all these cables I don't use
What case are you getting?
It's an OK PSU. Can you find EVGA, Corsair, or Seasonic units where you live?
They are available in the UK but I'm limited to whats available at PC World cause of the voucher. I also don't really want to spend much more than £60
Ah, well in that case you're probably fine with a G550M then.
Cool thanks
Given the choice, if there's nothing wrong with your current PSU I wouldn't spend money on upgrading. Yeah GM is a decent unit but you won't be putting a huge load on your EVGA either. If it ain't broke don't fix it :/
"Rawr XD"
Those ones are perfectly fine, nothing wrong with it.
Though a bit older (2 years or so) but still good PSU.
On 2.12.2017 at 6:59 PM, artificialRAGE said:
Get the CX. Just make sure its the grey version not the older green one. Its better than the Cooler Master GM series.
Why?
The G-Series is pretty good and CWT as well..
"Hell is full of good meanings, but Heaven is full of good works"
My main thing is the mess. I hate it and have to keep cleaning the loose cables every time I open my PC. It can get pretty dusty cause my PC is in my room. I also have cats.
