My friend upgraded some time ago from a 760 to a 1060, but he has a recurring problem with almost every game he launches. What happens is that after 5 to 15 minutes in game, frames drop to 15-20 with no apparent reason. He tried reinstalling drivers (using DDU) and games, but still nothing has changed. The only thing that "fixes" this is closing Discord (which we use to talk), but we kinda need it.
Has anyone ever had the same problem? How could he fix it?
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/868064-fps-problem-with-gtx-1060/
That sounds strange.
What maybe can help:
- try a clean install of discord
- check temps of the gpu/cpu (and utilization) in msi afterburner
- clean install of the gpu drivers
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
all three already tried, temps are always below 65 and drivers had been clean installed multiple times
how much cpu/ram usage does discord have when he gets low fps?
can't tell you now as he's not at home to test. will update as soon as possible
Some more things to look at:
- Does it happen with discord only or also with other communicate software (Teamspeak, Skype etc.)
- NVIDIA control panel - set to performance
- Disable Xbox app in windows
- What is his mobo? Maybe try updating it
- Power Options from windows 10 and check if it's on High Performance
Thing from the internet (No idea if it works or even what it does)
- If it's an older mobo try switching HPET off
sorry for taking so long, but I might have an answer. Discord wasn't taking up any resources, so I made him check with malwarebytes after joking that he might have a bitcoin miner. Turns out he had multiple instances. I'll update again if this was the problem after all
Wow, that's scary. Glad you found them though.
it's time
that stuff was quite advanced. not the crappy javascript miner from coinhive, not even a blatand .exe running in background and visible in the task manager. This stuff was inside windows registry, sneaky little fucks hiding behind windows defender and task scheduling stuff.
oof.
it's time
