So i know, this question is kinda dumb but i put in my CPU (i7 6800k) the wrong was, noticed it and swapped it round. After completing the mainetenance, I went on and tried to boot up my system but got boot error and a red CPU Q-LED. So I opened my socket, examined my CPU and noticed that one corner was kinda... snipped. Im just asking for help i know i should have noticed earlier and will propably have to buy a new Processor and maybe a new MoBo
https://linustechtips.com/topic/867011-help-cpu-broken/
oh, that looks bad... if none of the traces were damaged, it should still be ok, but the problem is there isn't really a way to confirm that.  The PCB is layered and would contain many traces through that area in all likelihood.
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764205
Just now, GameTime007 said:
Also, waht would be the best method, since its fairly ridgid
eh...there isn't really a good method per se but I would use some sort of flat object to try and flatten it out.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764236
I'm just curious but aren't those things (cpu's) keyed and only fit in one way?  If so, how did you get it in without forcing it?  Could be that is why the corner is bent the way it is.  Like said above, put it on a flat surface and try using very light pressure to try and get it back in to the original shape.
But to be honest, I think it's toast.
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764263
Well it kinda fits in the wrong way. And LGA, especially X99 requieres quite a lot of „force“ to get the CPU installed. Also it always cracks a little, so you cant hear if everything is goin fine or if you are currently killing your Processor. Honestly, LGA is kinda shit
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764271
Ah, another good reason for me to stick with AMD.  I'm currently running an AMD FX8370 at 4.335.  I have a crappy cooler so got to wait for a few more dollars before I can upgrade.  And I don't know what to upgrade to yet.  Current cooler is an Arctic 7.
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764285
Cool
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764321
8 minutes ago, GameTime007 said:
Wow, just WOW THANK YOU SO MUCH!!
ITS ALIVE!!
Dang you're lucky
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764336
1 minute ago, GameTime007 said:
Really reaalyy lucky, i should now treat this thing with care
When you're done with it, sell it on eBay as " practically new" with " just a few dents " ?
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764351
2 minutes ago, suh)))))))))))) said:
never say stick with amd and a fx8370 in the same sentence ever again
I have never had any problems with any of my AMD chips.  I don't have any problems with my FX8370 either.  It runs fine.  Obviously you are a die hard Intel user.
https://linustechtips.com/topic/867011-help-cpu-broken/#findComment-10764353
