Power Consumption
How are we supposed to know that when we
1. Have no idea what electricity costs in your area
2. Have idea what you do with your computer
3. Have no idea how often you use your computer.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/866666-power-consumption/#findComment-10760339
That's why I said approximate, and I will be gaming about 3-4 hours a day
https://linustechtips.com/topic/866666-power-consumption/#findComment-10760349
10 minutes ago, XxBatman99xX said:
It's 80+ gold, you can see that in the part list, should have mentioned that though
80 PLUS Gold just means it hits certain efficiency at pre-selected points based on Ecova's standard.
You also should do this yourself, with your own location's costs for electricity per KWh, seeing if it differs at different points in time during the day, and considering the fact that we don't know how much power your system is consuming at any given point in time since you're probably not hammering the system to its full capacity all the time.
https://linustechtips.com/topic/866666-power-consumption/#findComment-10760397
That computer will use around 300-350 watts when gaming.  Let's say 350 watts because it's a nice round number.
When you're not gaming, it's going to be less than 100 watts.
Your power supply is around 90% efficient, which means out of 100% of the energy that it takes from the socket, 90% is actually going to components.
So, if 350 watts go to components then the power supply will consume  350 x 100 / 90 = ~ 390 watts from the mains socket. We can round it up to 400w to keep things simple.
If your computer components are using 100 watts, then your power supply will consume 100 * 100/90 = ~ 110 watts.
You pay for your electricity in kWh ... that's 1000 watts over the course of one hour.  So if you're playing games on your computer and your power supply is taking 400w throughout the hour, that means you will be billed for 0.4 kWh for that hour and in four hours you're going to be billed for 1.6 kWh.
If you play games every day for 4 hours, then in 31 days you're going to pay 1.6 x 31 =  50kWh.
How much you pay for each kWh varies from country to country, from state to state ... I think in US the average is around 0.10$ for 1kWh , so that means you'd pay 50 x 0.1 = 5$ at the end of the month.
When you're not gaming, your computer will use 110w, so it would take about 9 hours to reach 1kWh, or ~ 3 kWh if you'd keep the computer running 24/7... or 100kWh per month, which translates into around 10$ a month extra on your electricity bill.
Note that speakers (maybe 10-20w) and the monitor (30w-50w) also matter, and most people forget about them.
https://linustechtips.com/topic/866666-power-consumption/#findComment-10760418
