Wireless headsets?
    Your not going to find decent and bluetooth in the same category.  Your best bet are the G933 which comes with decent amount of adapters for everything or the G533 for straight PC experience. Even  cans like the Void pro from corsair and Razers products are subpar in the wireless space...even logitechs so in that regard I wouldn't pay the extra money and go with the G533 since they are all roughly on the same footing. There are bluetooth ones like the Logitech H800 but it is just terrible.
https://linustechtips.com/topic/866245-wireless-headsets/#findComment-10756390
Logitech G933 has a wireless variant.
I'm really happy with mine, they are quite pricey but do offer 10+ hours of battery (My battery is wearing out, originally I got 12+ hours).
If you are into RGB it does have lights that you cannot see but are flashy, for streamers this is quite handy. Although I leave them off to save battery.
Sound quality is just amazing, before this one I had a € 30 headset. Sound difference is huge.
Mic quality is good enough for Skype/Discord/In-Game voice. But do not go streaming/recording with it. Even with EQ's/Noise cancelation it isn't up to snuff.
Comfort is decent if you do not mind the weight. The fabric also needed 1 month to break in & become soft for me. Simple words: it hurts the first month, but after that it becomes really comfy.
There are other options, SteelSeries offers one. I looked at it, but seemed to be less in quality and wasn't available in Belgium.
TL;DR:
Give the "Logitech G933 Artemis Spectrum Wireless" a look.
Just leave the RGB off to save some battery and give it some time to break in.
Yes the name is long, and overly complex.
EDIT:
The headset uses USB/3.5MM/USB DONGLE but no bluetooth.
Bluetooth on a gaming headset isn't really a thing, especially high quality bluetooth headsets since most desktops lack bluetooth.
I guess you are on a laptop?
If USB is an option, this could work.
Uses a wireless USB dongle, if you get a usb extension cradle it improves range. I got mine from an old wireless B USB stick lol.
Edited by Sfekke
Added info about wireless options & that it doesn't come with bluetooth.
When the PC is acting up haunted,
who ya gonna call?
"Monotone voice" : A local computer store.
*Terrible joke I know*
https://linustechtips.com/topic/866245-wireless-headsets/#findComment-10756393
