Intel Core i5-2500K problems, help requested!
Solved by scottyseng,
Hmm, that is odd. The stock speed should be 3.3 GHz and turbo boost of 3.7 GHz.
If you have a good cooler, you should be able to push it. I would really just start playing with voltage. Sandy Bridge overclocks very easy. It's hard to say how much your CPU can be pushed because every CPU is different. You might be able to get 100-200MHz or more though at stock voltage (However, keep in mind by default motherboards kind of overdo it with voltage with auto for OCing)
I had my old 2500K going at 4.6GHz at 1.4v. I currently have a 2700K (I got it for$130, why not) last summer and it runs at 4.9 GHz at 1.45v.
Yeah, your CPU just needs an overclock and it'll keep up fine (Well, maybe not BF1, that game is brutal on CPU)
