Wondering if 3 slot and 4 slot spacing will result in significant difference in temperature.
I am currently using 4 slot spacing, but it is about time I have upgraded my system and motherboard I am looking at is 3 slot spacing.
Would like to get some input before I make the purchase.
https://linustechtips.com/topic/865628-temperature-difference-from-sli-spacing/
Spacing should at least be three slots, although the top card will still experience a temperature increase regardless.
There would be almost no difference between 3 and 4 slot, assuming your GPUs are dual slot.
The difference between 2 and 3 is a lot more noticeable, if possible use this config.
I'd do 3 at a minimum but if do 4 if I could. Like the look.
I have 3 slot and still see an increase of 10c on the top card. Not sure if 4 slot would make that any better but plan accordingly.
AMD Ryzen 1700x
ASRock x370 Taichi
Corsair Vengeance RGB 16GB GDDR4 3200
EVGA GTX 1080 Ti K|NGP|N
Fractal Meshify C
Samsung Evo 960 Nvme M.2 500gb & WD Blue 1TB
Corsair TX850M Gold
Alienware AW2518H 240Hz Gsync
Audioengine A2+ & Sennheiser HD6xx /w Fiio K5 Pro
Deepcool Captain 240Pro V2
Vortex Race 3 Cherry Mx Red
Corsair Vengeance M65 PRO RGB
Bump,
The reason I am asking is because the graphics cards I have are 2.5 slot cards, so moving from my current 4 slot spacing (1.5 slot space between the cards) to 3 slot spacing (0.5 slot space between the cards) would result in less space for airflow.
Well it would work. Gonna  be bad airflow regardless. But its better than nothing.
