So I'd like to build PC. I've never done it before and I'm afraid it won't work or something... Anyway, I just wanted to ask what do you think about it.
https://de.pcpartpicker.com/list/mnkRZ8
And this case: https://www.x-kom.pl/p/380830-obudowa-do-komputera-genesis-titan-660-plus.html
https://linustechtips.com/topic/864978-my-first-build/
I just tweaked it a bit, and added RAM that's actually showing up. Also better PSU.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  (€101.23 @ Amazon Deutschland)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  (€64.59 @ Amazon Deutschland)
Memory: *Kingston - Savage 8GB (2 x 4GB) DDR4-3000 Memory  (€85.98 @ Amazon Deutschland)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (€41.42 @ Amazon Deutschland)
Video Card: *Zotac - GeForce GTX 1060 3GB 3GB Mini Video Card  (€198.00 @ Amazon Deutschland)
Power Supply: be quiet! - Pure Power 10 CM 500W 80+ Silver Certified Semi-Modular ATX Power Supply  (€65.95 @ Amazon Deutschland)
Total: €557.17
Generated by PCPartPicker 2017-11-25 18:45 CET+0100
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745161
Don't be scared, being scared is the worst thing to feel when building a PC as you actually make more mistakes.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745162
Total: €557.17
It says that this RAM isn't available and I found a deal for 2400Mhz + B350M-A somewhere else. ;) So Zotac is better?
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745169
Oh. Then disregard the RAM.
Zotac is cheaper and just as good :P
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745171
Just now, nishe1 said:
But I found a deal with MSI a bit cheaper than Zotac. ;)
You might want to tell us all the deals you found.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745181
5 minutes ago, nishe1 said:
I'm not sure if you're insterested in deals from Poland ;)
Meh.
But so we can make sure we aren't recommending to you worse deals.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745201
48 minutes ago, JDE said:
Meh.
Price of those GPUs were pretty similar but they add VAT or sth when you check-out so it's a bit more expensive... I'll probably won't even use Amazon. Anyway, thanks for your help. :)
Any chance for cheaper PSU which is also good? Maybe Corsair CX450 450W 80 PLUS Bronze?
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745276
Only if it has a grey label, and you don't plan on any massive overclocks.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/864978-my-first-build/#findComment-10745491
