ASUS Hyper M.2 x16 Card Expansion NV Me M.2 drives and speed up to 128Gbps
I bought this card to add to my build but am a bit confused as to the key needed I have been told that it comes with the key on the prime x299 deluxe and I have read that it DOESENT  come with the key, my boot drive is 32GB intel optane with 1tb 7200hdd with 4tb in raid 0 I will be putting 2 Samsung 960 Evo 500gb m.2 in it for the time being with 6 more being planned for the future what will be the best use of this set up ? build is not complete as of yet
never let fear stand in the way of your terror.
                                                    If you like anything I write feel free to quote and pass it on
        however, if you disagree with me and have a strong opinion.....better be riding a fast horse
Intel has not released their Vroc key yet so raiding the cards will be difficult. Also, you may not be getting x16 to the card if you have 2 graphics cards. If you put 6 m.2 drives in there then you will be using 24 lanes solely for m.2. Also, the m.2 connectors on the motherboard sometimes goes through the chipset which means the drive will not get its full potential. Linus just released a video on this.
was that the video of the 4 Evo ssds  I will be just starting out with 2 960s as I realize this is fairly new
If you have the 7740X (I assume you have this one based on your profile) You have only 16 CPU lanes (compared to 44 lanes on the i9s) So it's basically impossible to get any kind of SSD raid with adequate performance on this cpu (1GPU will eat every single lane this questionable x299 cpu has to offer).
Main PC
i7 7820X @4.5Ghz/Asus X299 TUF Mark I/GSkill TridentZ RGB 4x8GB 3000MHz/MSI GTX980Ti Gaming 6G/960 Pro 512GB/850 Evo 500GB/2x2TB HDD/Enthoo Evolv TG/H115i w/HD140s/Corsair HX 850i
Other PCs
i7 3930K/16GB DDR3 1866Mhz/Big Bang Xpower II/MSI GTX 760 TF 2GB/BQ DP P8 1000W/850 Evo 250GB/2TB WD HDD
i5 6600K/BQ Dark Rock 3/16GB Vengeance LPX/ASUS Z170 Pro Gaming/Intel 120GB SSD/GTX 1060 Strix/1TB HDD/Corsair RM650
R5 1600/8GB Vengeance LPX 2666Mhz/ASUS B350F Strix Gaming/ GTX 1050Ti Strix/850 Evo 250GB/1TB HDD/BQ 530W
Notebook Lenovo Ideapad 710S 6500U/8GB/256GB NVMe
Peasant gaming stuff PS3/PS4 Pro/PSP/PS Vita
I have a i7 7820 on the way
I'd cancel that CPU and get at least a 7900X if you are serious about that NVMe raid. 7820X has only 28 lanes (fine by me as I don't plan any nvme madness :) ) and when you want to use that many SSDs you will use 24 lanes of that 28 available and let's not forget that gpu :)
Main PC
Other PCs
well I don't think I can cancel it (you know how Amazon is) but thanks for the advise! also should I remove the mob when i replace the cpu or can I just leave it in place its a full tower case and yeah i dont have the xtra 500 bucks for an I9 lol
Replacing a CPU is an easy thing especially on x299 because the backplate is mounted to the mobo so there's no need to remove the mobo from the case. Also if you'll stick to that 7820X I don't think it makes sense to go for that 6xSSD raid thing :/
Main PC
Other PCs
ahh ok no sense in wasting money then I'll just wait a few more months then upgrade again I mean it IS a hobby lol as of this writing i only have 1 ssd on the way
