Thermal Compound
Solved by Cyberspirit,
7 minutes ago, ToXIc DevilZz said:So I ordered a BE QUIET! Pure Rock Slim and also ordered some ARCTIC ORACO-MX40001-BL MX-4 Thermal Compound, now the cooler has arrived I realise it already has thermal compound pre applied.
Should I clean it off and use the Arctic MX-4 or just use the pre applied compound?
Yes, you should. The factory pre-applied one isn't terrible but, the one you got is better.
