I just build my first Ryzen build and i experienced some odd behavior. But first my spec:
Cpu: Ryzen 1600
Gpu Palit 1060 jet stream
Coller: Silentium PC Fortis V2
Ram: Corsair Vengance LPX 3000mhz 15-17-17-35 CMK8GX4M2B3000C15R
Mobo: Msi B350 Tomahawk bios 1.9
After assembly my system don't even post. It turned out that one ram stick is not working, and after removing it my system post and i was able to install windows with 1 stick only. I was even able to OC ram up to 2800mhz t 16-16-16-35 (I read that some people are able to run that memory at 3200mhz 16-18-18-36 at same motherboard, but in my case system won't post with that). I was going to RMA RAM but out of curiosity i checked  memory in z170 system, and, to my surprise i find out that both memory sticks are ok and run at 2933 15-17-17-35 with no problems. At that point i was thinking that the problem is with my motherboard rather than ram, so i took ram from z170 build (G.Skill 3000mhz 15-16-16-35 2x4gb). And it works flawless, easily overclocked to 3200mhz  16-16-16-35! So my mobo is ok. As a last resort i put all 4 sticks (G.Skill and Corsair) together and... it works as well, all 4 sticks was detected and i was able to oc to 2444mhz.
Any of you have idea why one of the corsair don't work with my motherboard at all unless i put two additional sticks? I would understand if any of those corsair sticks didn't work, but that is odd as hell!
https://linustechtips.com/topic/862808-my-first-ryzen-build-odd-behavior/
If you haven't yet, you should make sure it's the RAM that's bad and not the DIMM slot itself. Take the stick you know works and put it into the second slot (or vice versa with the "bad" stick).
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
18 minutes ago, Judd said:
Why don't you switch the RAM. The corsair ones in the z170 and g.skill in Ryzen
That would be perfect but i can't do that because:
1. Z170 system isn't my, i just borrowed it to test everything and owner want his sticks back
2. G.Skill sticks are blue and don't match with rest of the system B|
