Cpu: AMD Phenom II 1090T @ 4.1ghz Air cooled
Memory: 1600Mhz 12 gb
Mobo: MSI GD70 790fx
850watt corsair power supply
2x120gb SSD Raid 1 boot.
2x 1tb seagate Constellation 128mb cache
Video card: HD 5770
wondering what would be a good card for this system. I've always ran low end cards which limits my experience in gaming. To my knowledge it plays everything I've played with medium-high settings @ 1080P but would like to be able to go to like High-ultra @ 1080P
https://linustechtips.com/topic/86268-best-gpu-for-my-build/
7970/280x/770--whichever is cheapest.
https://linustechtips.com/topic/86268-best-gpu-for-my-build/#findComment-1171469
Video card: HD 5770
GTX 760 imho, if you like amd then the 7950 / 7970 (I don't like the drivers but that's personal taste)
or a 770 if you can, I personally still max out everything on my 660 Ti though (the 760 supposedly performs a bit better)
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/86268-best-gpu-for-my-build/#findComment-1171477
The R9 270X is a great $200 budget range card but if you can afford a GTX 770 it would be the way to go for sure.
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
https://linustechtips.com/topic/86268-best-gpu-for-my-build/#findComment-1174152
